I have the following behavior with my Samsung Galaxy S5, Verizon, Stock.
Short version:
Long version:
I will notice that the volume is low - it seems too quiet, and when I use the rocker to turn the volume up, the perceived volume is not in line with where the slider is (e.g., let's say 1/2 is normally loud with my earbuds; when volume has dropped, 2/2 is not as loud as 1/2 usually is)
This happens with both AUX (earbuds) and bluetooth (car stereo, also standalone speaker) outputs.
The fix is to have the notification chime go off - either new mail or a new text message. When that sounds, it sounds at normal volume, and the speaker volume is immediately boosted back up. (So if I've got earbuds in, I'm clawing them out, because my music went from soft to loud). It's gotten to the point where I send myself a text message when I notice the volume is diminished so I can reset it.
Has anyone else noticed this symptom?
Does this have anything to do with the terrible, horrible, no good, very bad "Google is concerned you might not have noticed the volume is loud and is nannying the volume down for you so you don't go deaf" terrible horribleness? (Note to Google: Bad feature. Remove it.)
Any help or pointers appreciated.
Thanks!
Short version:
- Sometimes volume is lower than normal (same point on slider bar means less volume)
- Notification beep from incoming mail or text will reset volume
- Why? How to avoid? Related to Google's Nannyverse "you're going to go deaf!"?
Long version:
Thanks!
