Volume/silent/Vibrate<<--Moto X 2nd --Lollipop ---5.0
atrixfll
88
Am I missing something ..I can not find quick settings for this Basic settings..
Do I need and app... ??? Please tell me not
davidnc
Super Moderator
Moderator
Jun 8, 2010
8,905
517
113
To get phone in silent mode touch where it shows none,it will show if you want it set for indefinite, or how many hours .
The same goes for priority,it will ask for indefinite or how many hours you want it set for.
So you dont use the volume slider to set it to silent you touch none and then set it for indefinite or how many hours you want it silent.If you use the volume slider and move it all the way to the left it will be in vibrate mode.
A box pops open when you touch none with the options just mentioned.
Edit:
None: your phone is silent for rings/messaging
Priority :means your contacts rings or /messaging sounds will still be heard .I think for all contacts (it might just be for favorites I forgot for sure lol )
All: Rings /messaging as normal
Clocks
2,009
18
The volume rocker changes volume. With the volume popup open click on the Bell icon to change it to vibrate only or click the volume all the way down. "None" is absolute silence (i.e. not even an alarm clock will sound).
"Priority" is a new setting that silences all notifications except those you deem to be "priority interruptions" which will be allowed to ring or vibrate at your volume setting. You configure which interruptions are priority under "Settings">"Sound & notification">"Interruptions"
Robisan
745
This is what's annoying about the Moto apps now relying on the single Downtime setting. For "Meeting" I want the None setting. For "Sleeping" I want the Priority setting, where favorites only will ring. All of this was customizable in the Moto app settings under Kit Kat.
benhaube
809
These new volume settings are the only thing about lollipop I don't like. It really seems like someone at Google sat down and decided to complicate the process for no reason at all.
cellomj
135
Re: Volume/silent/Vibrate&lt;&lt;--Moto X 2nd --Lollipop ---5.0
If you are a power toggles user, add the volume toggle. With each tap, this will cycle through volume on, silent (indicated by a star in lolipop), and vibrate. You can put the power toggles on your homescreen or notification pull-down. It's helped me save a step or two since lollipop went and messed with our volume controls 😠
Clocks
2,009
18
If you are a power toggles user, add the volume toggle. With each tap, this will cycle through volume on, silent (indicated by a star in lolipop), and vibrate. You can put the power toggles on your homescreen or notification pull-down. It's helped me save a step or two since lollipop went and messed with our volume controls ������
The star is actually "Priority", which is "silent...except for alarms and items you deem as priority in the Interruptions menu in Sound & notification settings"
Silence (total absolute no-alarm silent mode) is a circle with a line through it.
(I agree with others that it is ridiculous it takes long threads, youtube videos, and blog posts to explain how to change the volume of your phone with android L...wtf google)
cellomj
135
Hey thanks - you're totally right about that. So if you put it in priority mode and don't allow any interruptions, alarms still get through. Wish we could opt out of the whole thing and go back to the kitkat implementation.
sharkita
549
If you are a power toggles user, add the volume toggle. With each tap, this will cycle through volume on, silent (indicated by a star in lolipop), and vibrate. You can put the power toggles on your homescreen or notification pull-down. It's helped me save a step or two since lollipop went and messed with our volume controls ??????
That's exactly what I did. I never need to switch to silent, but I do use vibrate, and adding the volume toggle to my Power Toggles widget fit the bill perfectly. I can switch vibrate off and on quite easily with that, rather than go through all the priority stuff. I concur with benhaube, Clocks, and others that Google took a simple setting like volume preferences and made it way more complicated than it needs to be.
tostler
Active member
Jun 1, 2010
36
I agree.
I replaced my 2013 Moto X for a 14 and I still haven't figured out how the Moto Assist and notifications integrate. I'm hoping the 5.1 update addresses this issue. I want this to be automatic. Not something I have to monkey with every time I head into a meeting. I also use Light Flow and I've yet to find a config that works. Half the time when Moto Assist senses I'm in a meeting, it changes the notification settings, half the time it doesn't.
Not the end of the world, but a funky Moto App is worse than not having it at all.
fallingOutOfLoveWfithTech
