• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues please let us know in this thread!
volume - wired headset vs. bluetooth headset
monkeycsk
273
i find the volume for the stocked wired headset for the note8 is rather low even when i set the volume to max.
however, when i use the apple airpod bluetooth headset, the volume is considerably louder which i find very interesting because i always thought wired headset is louder than any bluetooth headset.
anyone has the same experience?
chanchan05
Q&A Team
Nov 22, 2014
8,520
Being wired or not has nothing to do with volume. It's the drivers on the headset itself. Also, the ones bundled in the Note are in ear types, which means they expect you to get a decent seal to get proper volume.
monkeycsk
273
ok, so do you agree the volume for the note8's drivers is low?
j_hansen
3,096
I find the AKG ones fairly loud but my Spigen Bluetooth one are definetely louder, however, like previous poster said it is all about a good seal and the Spigen ones just seem to be a perfect fit for me.
amyf27
9,842
I use Beats by Dre bluetooth over ear headphones and have fantastic volume
chanchan05
Q&A Team
Nov 22, 2014
8,520
Anyway, I actually find the included plugs small. So you might need to get third party plugs to make them work better, like Comply foam plugs.
monkeycsk
273
i agreed with you totally. my friend and i both find our stock wired headset has very low volume. i really don't think it has anything to do with seal.
