VRS S7 Edge Single Fit Case Review
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,106
203
63
Our friends over at VRS Design was nice enough to send us some cases to review. Overall, the cases are similar in quality to Spigen or Caseology cases. They aren't as refined as Otterbox, Lifeproof or other high end cases, but those also cost a lot more. With the exception of the wallet case which came in a box, the remaining cases came in a generic gray plastic bag, which you can see in some of the review photos. Case needs are so wide because many people have different needs. I tried to point out what I thought was important, and also provide lots of pictures, so that you can see in detail what it looks like on the phone. The pictures where taken with and without flash, and I picked the ones that looked best.
This particular review focuses on the Single Fit Case, but you can read my reviews on the other VRS cases here:
S7 Edge Triple Mixx Case
http://forums.androidcentral.com/re...area/702207-vrs-s7-edge-triple-mixx-case.html
S7 Edge Crystal Bumper
http://forums.androidcentral.com/re...2-vrs-s7-edge-crystal-bumper-case-review.html
S7 Edge Hi Pro Shield
http://forums.androidcentral.com/re...-vrs-s7-edge-high-pro-shield-case-review.html
S7 Edge Crystal mixx clear Case
http://forums.androidcentral.com/review-templates-staging-area/702217-vrs-s7-edge-crystal-mixx-case-review.html
S7 Edge, 10, Note 4 Leather Wallet Case
http://forums.androidcentral.com/review-templates-staging-area/702218-vrs-s7-edge-leather-wallet-case-review.html
Single Fit Case
This is a one piece molded matte TPU case The one I got was in Phantom Black but it is also offered in Blossom Red, Ice Mint, Smokey Gray, and Snow Pink.The home and power buttons are separate pieces and area bit loose, and makes a rattling sound if you shake the phone. There is a moderate lip at the top and bottom of the front. The Phantom Black color, looked good on good on my black S7 Edge.
The fitment is pretty snug, however, it pushed up my Zagg Invisible Shield HD screen protector. The buttons feel loose, and require a moderate amount of force to activate. The holes are a good size and centered and the vast majority of micro-usb cables and headphone cables should fit just fine. It feels comfortable to hold one handed. The grip is not very good due to it being matte,however, also it doesn’t show fingerprints because it is matte. II sometimes put tissue in my pocket, and notice that the case is a lint magnet, though if you don't have any lint in your pocket, then you should be ok.
dayssss2
