wall charger?
Xanth269
511
26
Hello all,
Just got my VZ GN last night, so far so good, no issues but its my 1st Droid.
I want to get another wall charger for the office, should I stay with OEM or can I use my old BB or buy an after market?
Thanks.
Dave-
Any USB charger that makes it work. Some may not be powerful enough, as it really takes 1 amp to run these things. USB from a computer is usually limited to 0.5 A, which may not be enough to charge it quickly, especially if you are using it.
From another thread, if you are using it as a GPS to navigate with the screen staying on, you need 3amps to keep the battery from draining. Of course that is an issue for a car charger, not a wall charger, but I wanted to point it out anyhow.
BarMaestro1
