Water
Expydude
204
5
Hey all, where can I get the water live wallpaper like what's on HTC? I can't find it anywhere
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
I've tried but it either don't have or I'm typing in the wrong name in search. I tried water which is on the HTC but no luck as of yet
Thank you! Couldn't find the actual one but found a good equivalent. This has to be the best forum for Android. I've always been helped out with any problems I've had
Here is a set of video live wallpapers of water that cause practically no battery drain to your phone. Unfortunately, I can't use them on my Tab 10.1 with ICS 4.0.4 because it is not a supported device. I do use them on my Tab2 7 and my S3.
Apps by Bonne App! - Android
