Weather not working on charging dock
Theodore55
13
Everything is working but the weather. It says F for farenheit but no city or temperature. It found my city when I first put it on the charger, but it won't show any info. Thanks for any help.
keepsakenw
Active member
Nov 8, 2009
29
I have noticed the same issue. I thought it was just too cold for it to show...in the mid teens right now. Not sure what the problem is.
Adiliyo
2,412
49
mine was working last night (the last time i looked at it)
but i think i remember it not showing temps closer to when i bought it.
i think it has to do with it just not getting valid data from wherever it pulls the info from
SLEEP3R
5
mine started to do the exact same thing as of 3 or 4 days ago. I have set location manually , had it automatically find it , unchecked the show weather and so on .
sometimes it works and now most the time it dosnt . just like others it has location but just shows F and no info.
so it seems more than a few of us are experiencing this problem . and BTW it worked just fine out of the box .
khessjr
If I power the Droid off, then back on, then place on the dock, the weather shows. If you remove the Droid from the dock to use, then place back on the dock the weather info is gone until you power the phone off and back on again.
