Try removing the widget from the screen (not uninstalling it) & then put it back.
How can I do it? do you have an apk for it?Then try fully uninstalling the app, re-installing & then putting the widget back.
Which weather widget is it?
If it's the stock one, I don't have it, but it shouldn't be too hard to find it.
By the way, have you rebooted again? (I just want to make sure)
Clear the data in Settings > Application Manager > Weather Widget Main. That did it for me, if you haven't done that already.yeah I rebooted and yeah it is the stock one![]()
