WebOSDoctor/ReInstall issue. Screwed up CyanogenMod. HELP!
jeffmartinaz
16
K...I think I"m screwed. Installed the CyanogenMod and it was running well, with the exception of wireless kicking off all the time. I thought uninstalling and reinstalling would do the trick. Not the case. Now I have the triangle with the exclamation point in it with the text www.palm.com/ROM under it.
Went to the site and downloaded the WebOSDoctor and have tried the restor. I can hold down the home/power/volume up buttons and can get into recovery mode, but when I begin the install from WebOSDoctor, it stalls out at 12% on the install. Tried it three times and same problem.
Anyone know how to completely wipe this thing clean? I really don't care about using WebOS. Just want to get back to CyanogenMod. Help, please...
Hi, have you checked the suggestions here?
http://forums.precentral.net/webos-internals/295881-webos-doctor-12-issue-fixed.html
(edit) Ah, I see you've registered on PreCentral already ...
I did. I just don't understand enough about using novaterm. The instructions are written for someone with a little background knoedge. I have zero. I was able to open novaterm and start the install again, but got lost in the process. Anyone have a more detailed explanation??? Thanks!
Twousay
