- Nov 19, 2009
- 408
- 13
- 0
About a week ago I was trying to run Ustream on my Droid to listen to the Android Central Podcast. When I tapped the icon the screen flashed quickly like it was trying to load the program but went immediately back to my home screen. I tried it again a few more times with the same result. I uninstalled, redownloaded, and tried again. Same problem. Tried it again off and on for the last week including doing phone reboots. No luck.
The second problem started on Monday. My Slingplayer app does the same exact thing. I cannot do the delete and reinstall from the market due to it not showing up for Froyo Droid users. I did go to an older copy I had backed up but had no luck.
I have tried both on wifi and 3G. I am using CM6 RC2. Both apps worked fine using this rom for about a week before the issues began. I even tried reflashing the rom.
I am probably the only one having these issues, but it is worth a shot to see if anyone else is dealing with it or may have solutions.
BTW I am not using any theme and am using the default CM6 RC2 kernel.
Sent from my Droid using Tapatalk
