Were is my downlode folder plz tell me plz i need help finding it
jasonandrews25788
2,328
It should be the default download folder of your default browser. Open your default browser. It should be name just "browser" go to the settings of it and go to advanced look for save location. This only works if you haven't altered/replaced it yet. If you did, you can set the browser to default settings first for you to see it.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,587
4,727
113
It depends on what the OP is using to download files. Most apps will use the main Download directory, but certain apps might create their own directory for downloads.
Nikoczzzz
