What case works with dock
No. Only thing that might work are things like Invisible shield, Phantomskinz, etc. not cases.
I use a TPU case from eBay, and it is easily slipped on and off to use in my car dock, which I use 2x a day. Fits very snugly, and it is flexible enough, but stiff at the same time. I am confident, it will not stretch or get loose over time.
If you search the Fourm on the subject there was a post on here where a Member gave detailed instructions and I believe a You Tube video on how to get the Rocketfish case to work with the dock. Hope this helps.
You could always ditch the Verizon dock and get a universal one from Akron for 19 bucks. I bought one a few weeks ago that has multiple attachment options and works with any case that you might have on it.
Does it come with the magnet to put it into car mode?
in the cardock, if you remove the inner piece which seats the un-cased phone, on the back it says that it will fit with 'motorola' cases. Apparently that doesn't mean Verizon cases. Anyone figure that one out?
tota
