I have a six month old Epic 4G, rooted, CWM recovery, but otherwise stock. I used Root Uninstaller to remove three of the annoying preloaded apps that I never use. I have a 32GB SD connected to the phone.
The problem: I have a very irritating "warm reboot:" problem that is making me crazy. The symptoms:
1) After booting, the phone is sometimes extremely laggy (obviously something is taking CPU).
2) Within a few minutes, the screen goes black and the four soft keys light up.
3) About ten seconds later, the GUI restarts and it starts scanning the flash.
4) This always completes. Within seconds to minutes after scanning completes, this happens again.
5) If the screen is off when it "reboots" then the screen first turns on briefly, then goes black.
What else I notice:
* The "uptime" reported is not reset. It increases as if there was no "reboot."
* This is not a real reboot. It looks like the kernel is not rebooting, just the UI layer. (?)
* Once I can get it to boot and not reboot, it's stable for days.
* Using the phone right after it boots seems to increase the chance of this happening.
* In the past, if I disabled WiFi and 4G and then went into airplane mode, this would greatly reduce the chance of this happening, but now my phone has been constantly warm rebooting even in airplane mode.
* This does not appear to be correlated with phone temperature. The phone can be cool to the touch or warm to the touch and this will happen.
Questions:
1) Is this a known issue that is not present in a 3rd party ROM?
2) I've tried wiping caches before. Makes no difference.
3) Does moving a lot of apps to SD cause this? With only 1/2 GB of built-in app memory, I have no choice but to move almost everything to the SD.
4) If my SD is full (say, of backups), does that make this more likely? Note that the scans report that they completed before this reboot ever occurs.
5) Is there a real name for this "reboot" that I can Google for? When I search for "reboot loop" or "warm reboot" I get unrelated failures. I saw one thread where someone mentioned a "sense reboot" but that seems to be an HTC thing?
What is the best solution for this? Thanks!
Note: I never applied the latest update because I'm rooted so it doesn't install.
What else I notice:
Questions:
