what does it mean if led light boinks quickly while DInc is on charger?
DikaiaKnight
206
4
Today for the first time ever my DInc's led started blinking quickly when on the charger. By quickly I mean about half second intervals. It is only while on the charger and there are no notifications in the bar. It stops as soon as I unplug it from charger and does not always re appear immediately when putting it back on.
I am using an oem blackberry charger at work. Anyone know what the heck is going on?
That usually means there is an error with the battery. Mine does that when I am charging and using navigation because the battery is overheating. Pull the battery, inspect it to make sure it has no issues, let it sit out for a bit, insert battery, and try to charge again. If the issue persists them take it back to Verizon sooner than later.
It could also be caused by a faulty charger or usb cable. But if it goes away when you unplug and replug the charger it sounds like you could have a bad battery / overheated battery.
zeke
