What does the arrow on the top right corner of note 4 means?
janje
Hi can anyone tell me what does the arrow means on the screenshot and please tell me how to get rid of it.
Thanks..
Nakrohtap
Trusted Member
Nov 16, 2011
3,078
37
I just checked the icon glossary and it's not in there. It must be a downloaded app that you installed. Is it there all the time? Can you look at your "running" apps to try and narrow it down?
iGalione
224
carrier, variant? any of that would also be helpful as well... I want to say wifi direct, but it is different, acutally has that with a fan blade on top
MightyMike
385
The only time I have ever seen those 2 arrows was when I was receiving an ATT update for the phone.
Posted via the Next Big Thing, My Galaxy N4
misterizzat
Hi.. im currently facing the same issue for my note edge.. asked several phone shops but none could solve it.. some said it relates to the call settings- voice over LTE allowances... im still waiting for the solution/updates on how to remove the arrows icon...
Noni Arif
it is called the VoLTE. if you. If you go to Mobile Networks > Network Mode and change it to some other setting. that arrow will disappear.
Kristin PandaCandy
My note edge also got the same thing... I think is linked to LTE.. I tried changing the mobile network from LTE to GSM, the arrows disappear... But appear again when i which back to LTE..
above30phoneguy
