What functions are acceptable when using adyclock on android Samsung edge 6
Jody Gurl
3
Can you access apps or the internet with the adyclock for Android? Does it lock or unlock your phone?
Welcome to Android Central! Are you asking if AdyClock prevents the phone from locking while it's showing?
FYI, AdyClock appears to have been removed from the Play Store. Since there often isn't a reason given for its removal, you may want to consider uninstalling it, in case there was a malware concern.
Well my daughter uses it all throughout the day and I don’t understand it’s function because she also used her clock.
fsd92
