What going on lately with my Note 2
acefutura
24
Hi guys lately my note 2 is starting to slow down and drain the battery over night ? I have tried all I can think of reboot clear ram catch etc. Also turned of wifi and 3g over night. Here is a screen shot.
What is this mediaserver ? Thanks Ace
If you tap on it it will give examples of what apps are connected to it. I would try a reboot and just see what happens. Maybe media server RAM is just stuck. If that doesn't help, yes reboot into recovery and wipe cache.
Forgive me for being a daft. But I take it a reboot is just shutting it down and restart it. And how do you reboot in to recovery and wipe cache. This wont remove everything to factory settings ? when I find out how to it. Thanks Again..
Click clear cache partition and it won't erase any user data.
From a Sprint Moto X using AC forums app
Thanks Golfdriver I got in to reboot and recovery and wiped the cache, using your helpful guide.
Still using a lot of power up thought. this is what I get when I tap on mediasever.
At least its down 11% from earlier.
Your signal looks pretty bad, I am wondering if that is part of the issue. Other than that, I have no idea.
Seems to be going alright today after leaving the battery out all night. Strange these note 2. Iv never had a problem with it in over a year but I have noticed a lot of user complain about this over night drain. Aw well its going alright for now.
Keep us apprised.
Usually I only see mediaserver drain like that when I'm streaming Spotify, pandora, or the like. It's related to sounds the phone makes and playing audio. I have noticed drain like that on my s3 and note 2 and on both a factory reset took care of the problem when other stuff wasn't working. It's an oddball glitch that happens on occasion. My main notice of that thing was when an update kicked in. I delay updates until I notice what people start saying happens.
Sent from Xperia Note
kolilco1
