What is a suitable Rom for solving lag \ Crashes \ Global \ high utilization of memory?
A
AC Question
Suitable Rom for solving lag \ Crashes \ Global \ high utilization of memory
My device has long suffered from serious problems of lag \ Crash \ heating \ high utilization of memory (RAM), even when no app is running in the background, or only the browser or music player are running.
the cleaning apps solve the problem for a few minutes, but soon the memory again filled (85-90%).
checking the device with "anTuTu Benchmark" app, gives a good score.
The operating system version is 4.3, and recently I restart the device, but to no avail.
What would you recommend for a Rom that will deal with this problem?
Thanks in advance
Rukbat
Retired Moderator
Feb 12, 2012
44,529
22
Re: Suitable Rom for solving lag \ Crashes \ Global \ high utilization of memory
"Cleaning apps" CAUSE the problem. They kill apps that Android needs running, so Android loads it back, so the cleaning app kills it, so ...
It's supposed to be. Android operates with as much RAM in use as possible.
I'd recommend uninstalling all your cleaning apps. When I was testing a few of them, the phone always ran better after I uninstalled the cleaning app. (And don't use anything by Cheetah Mobile - they have no idea how Android works.)
