what is the longest-lasting NON-UGLY extended battery for GN that can fit in a hard or TPU case?
badkitties
880
I must have the phone in a hard or TPU case, so the extended battery must be able to fit in it.
(either a dedicated case or an existing case that allows it)
Thanks!
I was able to get the 2100 in a hard case.
Sent from my Galaxy Nexus using Xparent SkyBlue Tapatalk 2
While My phone is the GSM version (with 2000mAh battery) I think the size comes out about the same. I use it in an Otterbox Commuter and it fits pretty good. There is a slight gap between the hard outer shell and the silicone inner at the bottom of the phone, but it's merely cosmetic and doesn't effect the use or protection of the case at all. Yes I know I'm talking about GSM in the Verizon forum... but from what I understand the Otterbox Commuter should still fit. You might have a slight gap as well, but it should be ok.
AS far as TPU cases, they might stretch slightly but it should still work with the extended case.
