What wireless charging pad are you guys using? Nokia's DT-910 charging stand is unstable.
Roy Droid
107
I have a Nokia DT-910 charging stand. It only charges in the vertical position which makes it very unstable. Any bump will knock it off its base.
I've been using the Lugu Lake pad for months. Cheap and the "sweet spot" is pretty large.
But unless that pad has something running up the back, your receiver coil is on the bottom of the phone, so it'll have to be charged in a vertical position regardless of which pad you use.
TYLT vu, always charged since its a fixed position. Have had good luck with the powerbot qi car mount as well.
Sent from my Nexus 7 using Tapatalk
TYLT VU for me as well. Really good reliable charger. Sometimes I wish it was angled just a little bit more upward though.
I also use tylt vu. They aren't cheap but do have 50% off sales every so often.
Patric2204
