T-Mobile Galaxy S8 What's a good portable power brick for S8?
VikeMan
3
Need recommendations for a good portable power brick for the S8. But please only recommend something you are successfully using with an S8. TIA!
Power 'brick' or a power bank? If you want the AC connector anything that supports QuickCharge 2.0 or at least 2A output should be fine (the latter won't do Fast Charging, though). I use older Samsung bricks and a couple LG (from the V20 and G4). Anker is a good, popular brand for chargers.
For Power Banks, same thing goes. I'm using an Aukey one, and while it works, it doesn't support QuickCharge so it's just standard charging at 2A. Prices have gone down significantly enough so that QC2 (or 3, but the S8 doesn't support QC3, so that's just 'extra') are pretty cheap now.
Or Anker makes Power Banks that support Quick Charge and their products are pretty good.
lalarat
