whats an easy way for me to get wireless tether?
There are one-click root methods over at XDA and SDX. From there you can install wifi tether for android. I would also put in superuser.apk once you're rooted. There's one you can just download in the market called superuser permissions. You'll need that before using wifi tether as you need an application to allow you to gain root access.
