What's draining my Samsung S4 battery running Android 5.0.1?
  • Start date Start date
A
AC Question
what's draining Samsung S4 battery running Android 5.0.1
Samsung S4 with Android 5.0.1 battery is draining fast
Re: what's draining Samsung S4 battery running Android 5.0.1
A factory reset will usually resolve this. You will lose apps and data so be sure to backup first.
Like DLK1 said, factory reset, if it doesn't fix the problem, you could always try downgrading (AT YOUR OWN RISK)...
bigdude76
