What's the best way to transfer settings between nonrooted phones
jaymzb0nd
160
18
I know Titanium Backup is awesome but it's only good for non rooted phones. I just received my replacement S3 and don't want to deal with having to choose all my sound and notification options again for the different settings and apps.
You mean rooted? TiBU only works if you're rooted.
I suggest you don't restore backups from one device to another, regardless if they're the same model or not. This can often cause force closes and issues within apps/settings.
Basically, it's better to restore everything from scratch and start with a clean plate. This stuff happens, and by the time you get the work around ready to go you could have already manually corrected your settings.
Sent from my SCH-I535 using Android Central Forums
Re: What's the best way to transfer settings between nonrooted ph
Yes I meant to say TiBU only works with rooted. Thanks for the advice.
How about your app data? Like my fuelogs or fame progress?
Sent from my Samsung Galaxy S3 using Tapatalk2
nivea531
