Where can I find Note 4 replacement parts?
tienakatj
8
Unfortunately (after only 2 days of use) I pulled my Note 4 out of my pocket to reveal shattered camera glass. I'm not certain how it happened, especially since I treated the thing like a newborn baby.
Now I am on the hunt for the lens cover replacement for this bad boy. Any ideas where to find it? I found the Note 3 and S5 replacements on ebay, but no luck for the Note 4. Any help would be greatly appreciated!
Thanks,
TJ
I haven't seen any :( Have you tried going to the store? You might be able to get a warranty exchange (not likely, but can't hurt to try)
Not if it goes through warranty. Again, it's a long shot, but it can't hurt to ask.
I'll look into the warranty. Also, no case on it at the time. I was waiting on the case to be delivered.
yeah, the case helps a lot. A coworker smashed his 2-hour-new iPhone 6's camera lens in the same way. A case makes it so that the lens never touches the surface.
With the raised camera lens I think this is going to happen a lot. I had an otterbox commuter on my note 3 so it wasn't an issue. I purchased a commuter for my note and didn't like it. I was thinking about trying to put something that was a little thicker right above the lens. Like a piece of adhesive foam or something to keep the lens of the surface
For now though with the protection of a tempered glass protector it's "*** up, face down....."
Hey man, keep us updated cause the same [removed by moderator] just happened to me.. im blaming this on amazon for their bull[removed by moderator] slow delivery
Thanks,
TJ
This happened to me today only a week of use I've addressed it with Samsung and it would take 14 days for it to get there so I just claimed a assurance claim it Pisces me off to have to pay 170 dollars for a camera lens
Any one find the camera glass? Took a month for me to break the camera glass.. Now on the hunt for glass! And a very thin case or solution. This phone handles so well with out a case, pitty we have to wrap it up. Might be on the look out for a glass protector for the camera only. Not sure if that exists... I have the breakable shield on the screen. Please keep this thread going until answered!
Hi,
I just had the same thing happen to my note4. i dropped mine though, so it's really my fault. Does anyone know if the S5 lens cover is the same size and would maybe work??
Otherwise if i find one i'll let you all know.
I have the same prob babied it one day i notice the camera lens shattered and i never dropped it. Anyone know if s5 lens replacement will work? I read we have the same camera
Sent from my Galaxy Note 4
thegttechkid
