Where is the business card scanner function of Samsung Edge?
  • Start date Start date
A
AC Question
There is a business card reader function on the S5 under contacts that seems to be absent from the S6 Edge.
Does anybody know where the business card reader has gone to?
Re: Where is the business card scanner function of Samsung Edge
On mine, I open contacts<more<business cards, then select add, and the scanner opens
The only one I know of that would be close to a "native" one is in the Samsung Galaxy Apps store.
Under "Galaxy Essentials" you should find SnapBizCard.
Mine is Verizon, totally stock; not sure why it is different from yours Rjack22
That's a cool feature.
My Verizon S6 Edge Plus does not have this feature. To bad, it would be quite useful to me.
Press to open your "Contacts" and then the "+" with the head figure to add a contact a blank contact will open. Also, the keyboard will pop up, which will block your view to "Scan Business Card." Press the return, the Keyboard will be removed, scroll to the bottom of the blank contact and you will see the Scan Business Card
