Why am I not able to switch between languages on my S3?
YassminK
S3 - Problem Switching Language
have set up the Samsung Galaxy S3 Keyboard with 2 languages: English (UK) and Arabic. The manual says I can switch between the languages by swiping the space bar key but that doesn't work. When I swipe, nothing happens. Both languages are showing the Samsung Keyboard settings section and both are checked.
Any ideas?
Thank you.
Re: S3 - Problem Switching Language
Hello Yassmink, welcome to the forums at Android Central! 🙋
Do you have the input languages to the ones you want?
In my case, I have English and Spanish.
Both work without sliding the space bar because my keyboard is set to learn how I "write".
But the space bar works if I slide it to either side.
You could reset the settings for the keyboard, restart the phone and try again to see if that helps.
ecomranx05
