Why do I only have one notification sound with Lollipop on my S5?
bostonbam
7
only one notification sound with lollipop on s5
I got the lollipop upgrade and now only have one notification sound, the whistle. And I can't figure out how to get my other notifications to work. They play in the notification menu and I can select them as default but they won't work when I get an actual notification. Ringtones work fine why won't my notifications? Someone please help
Re: only one notification sound with lollipop on s5
I've not had this trouble, but if you just received the update you might want to try a cache clear.
Power down your phone, now press & hold the power button, volume up & the home button until your phone boots into Recovery. Now use the volume rocker to select Wipe Cache. Hit the power button to make it happen - give it a sec to clear the cache. Now use the volume rocker to select Reboot System - hit the power button & run you phone for a bit. See if this helps*
Thanks I tried it and it didn't change anything. Idk what to d . I can't find anyone else with the issue or anything that works... Idk what to d . The whistle is the only sound that works and it's driving me crazy..
bendre18
