A
AC Question
I have also used many battery saving apps, such as Greenify, Cooler Master and more, should I continue using them? When I look at battery usage I see the number one battery drainer is the Screen followed by Android System. The Screen has 14% next to it and Android System has 3% next to it. After Android System I have several apps, including google, 3 games and Android OS, all of which have 2% or 1% next to them. I have tried many things to try to save my battery, I have learned what works for others doesn't always work for me :-(. On the same page it says I have "1h 13m 9s" I hope that information helps and whatever you recommend I will appreciate. Thanks.
-troubled Android user.
