Why does my battery drain even when I am not using my phone?
  • Start date Start date
A
AC Question
my battery drains even when I am not using my phone
no running apps
Re: my battery drains even when I am not using my phone
Everyone's battery does that. Android System is active in the background. The only fix would be to Power Off.
Even if the battery is removed from the phone, it will drain just a bit. Lithuim batteries (and most batteries) have a small bit of self-discharge. If the phone is going to be put away for a long time (months), check it every month and top it up if it falls below 50%.
If the battery is in the phone and the phone is turned off, it's still drawing a little bit of current, so that it can recognize the power button press to turn on. (It's done by electronics in the phone, it's not an on-off switch.)
And, as belodion sayd, if the phone is just sitting on standby, it's going to be running Linux, Android OS and a few system apps. That's why phones have battery standby ratings. The phone doesn't draw much when it's sleeping, but it does draw something.
I didn't think it was worth mentioning that a battery will drain even with the device powered off, but yes, of course it would slowly. After all, the whole universe is doing much the same. :)
cashinminutes
