Why does my battery drain so quickly with S Plus?
advicement
14
S Plus huge issue
Ok guys so , my S Plus had some issues with the battery ( at least I thought so ) meaning , that it would not charge. Now that I got a new battery , it drains really fast and the phone is always hot (40-45C on idle) . And it drains and stays hot on both batteries...What issue could it be ?
Re: S Plus huge issue
Welcome to Android Central!
Do you have an app running that takes up a lot of processes?
Thanks for answering !
No , I don't. I re flashed the software with Odin , factory reset a couple of times but the same result...It charges really slow (even with phone turned off) and really hot...It drains like 5% per 12 minutes of just being in standby with screen turned off.
Is the new battery a OEM one or is it aftermarket?
Well I don't know what OEM means , but the battery is a Gallop 1500MAh i9000 ( for the S1 ) and it is compatible , but it does the same thing on the old battery and the new one...
OEM is basically a battery from the manufacture. Can you post your battery stats?
janay2588
