Why Does My Nexus 6 Lose WiFi Connection?
  • Start date Start date
A
AC Question
This seems to happen quite frequently. I'll be going about my day at work or home and suddenly I see that my phone lost connection to the wifi again. So i have to reset the wifi on my phone to get it to reconnect.
Is there some way to fix this issue?
Try to forget it and then add it back as a new wifi connection.
Also might want to check and see if your on the fringe of coverage or getting interference. I find that my Nexus 6 has weaker antenna then some of my other devices. Meaning i get better, stronger wifi on my Note 4 and M9 then on my Nexus 6.
I had the same issue I believe lollipop to be the culprit mainly 5.1.1.. On good note I don't have the problem anymore since updating to 6.0... Just hang in their!!!
Gillian Kirton
