• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues please let us know in this thread!
Why does my phone work with speakers but not with headphones?
A
AC Question
I have a Droid Turbo and when I connect to *externally powered* speakers via the audio jack, the sound comes through fine, but when I try to plug in my headphones and listen to music that way, it does not recognize that they are connected and no sound comes through. Already cleaned out the jack, so there's no debris in it.
Rukbat
Retired Moderator
Feb 12, 2012
44,533
18
Are the headphones wired for the Turbo? Tip is left, first ring up from the tip is right, 3rd ring up from the tip is ground.
Normal stereo headphones (tip = left, 1 ring = right and shell = ground) should work, since they short the mic pin, telling the phone to use the internal mic.
Any other wiring won't work.
