• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues please let us know in this thread!
Why does my VZW LG G3 WiFi and Bluetooth turn on automatically and not let me turn it off?
A
AC Question
I have a Verizon LG G3.
When I power my phone on the wifi automatically turns on, but not all the way. It gets stuck in "Turning WiFi On" mode, the icon keeps flashing and I cannot get it to stop trying to turn on. Also, the Bluetooth turns on. Sometimes I am able to use the quick launch icon to turn off the BT, but not always. My phone gets really hot and then proceeds to restart over and over.
Even after a factory wipe, the first thing that happens when the setup pops up is "WiFi Turning On."
I have un-checked or turned off every option in wifi settings, turned off all location settings, even went into every factory app and turned off all "automatic location/sync/retrieval" setting I could find.
PLEASE tell me there's a fix for this!
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
161,962
304
83
Welcome to Android Central! That sounds really abnormal. Since it persists after a factory reset, I'd suspect either a firmware or hardware defect. Ask Verizon if they can give you a replacement; otherwise, you may have to deal with LG for warranty repair.
