• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues please let us know in this thread!
Why does my WiFi not Turn on At All after Lollipop Update on My Galaxy note 3?
A
AC Question
i have note 3 i update it to lollipop manualy by using odin and now it wont turn on wifi
anon(632115)
4,315
Did you use the correct ROM for your device model? Was this a custom ROM? What file did you use? What FW is on your device and what is the CSC code?
gr8leo87
7
Hi
I have exact same problem with my Note3.
- Phone was running Kitkat 4.4.2
- Got the phone updated to Lollipop by a repaor guy.
- came home to find that WiFi isn't turning on. It stays gray. WiFi tethering doesn't work either. BT and Mobile network are working fine.
- Wiped cache, Wiped data / factory reset. Didn't help.
- Found a newer version of the firmware and flashed using Odin. Same problem.
Can someone please help me get back my phone Wifi functionality.
Thanks
