Why does the battery of my Galaxy S3 drain like crazy?
Dini House
5
The battery of my galaxy s3 drains like crazy!!
One thing that causes massive draining is playing Clash of clans ( after 5 min. It drains about 15 %)
But even if i dont play it , after charging at 1 am , i wake up at 9 am , and its 85% , even with airplane mode and wifi turned off
Note: i always keep bluetooth, sync , s-beam, smart stay off ...
It even charged slow (8 hours for a fill recharge) but i fixed it by making minor changes on when i charge the phone
Any help with the drain issue would be appreciated
Gaba517
Active member
Aug 3, 2013
26
Go to Settings>Battery and take a screenshot, we need to see what is draining the battery.Do it when the battery has like 20% left.
Dini House
5
Today i played clash of clans for only about 12-13 minutes , cus its always above 40%
PoisonDarts8714
108
That isn't specific enough unfortunately. Go to the PlayStore and download GSAM Battery monitor. Go into settings of said app and turn on start on boot (i.e active monitor) charge to full and use normally..Then post screenshots of that, then 'app usage'
Dini House
5
Re: The battery of my galaxy s3 drains like crazy!!
Dammit i had 100% ...shut down my phone
Turned it on after an hour and it had 92%
Gaba517
Active member
Aug 3, 2013
26
I'm almost sure it's a bad battery if it drains like that even when the phone is completely turned off, you should try another battery and see if it behaves the same.
Posted from my beast Note 3
AxlMyk
1,217
Or charge it to 100%,and remove the battery. Then see what it says the charge is after several hours.
AC App on SGS3
MRG582
