Why doesn't my battery charge properly on my Samsung Galaxy Tab Pro 10.1?
Unitedfan519
4
Battery doesn't charge properly on Samsung Galaxy Tab Pro 10.1
The battery on my tablet only goes up to between 28 and 32 percent even if I charge it for several hours at a time. It has only started to happen recently. It also doesn't charge at all if I plug it into certain plug sockets even though the screen lights up when the charge level is below 5% which doesn't happen if I don't plug it in.
I have Android 4.4 if that helps. I am willing to provide any more information as requested. Any help would be greatly appreciated.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
164,092
2,785
113
Re: Battery doesn't charge properly on Samsung Galaxy Tab Pro 10.1
Welcome to Android Central! Are you using the original cable/wall plug? Have you tried different cables/plugs? Are you only using wall outlets, or also computer USB ports?
Unitedfan519
4
Really sorry for the late reply, but had separate issues with Internet recently.
Thanks for your reply. Yes, I am still using the original charger that I didn't have any problems with before and I have tried other chargers that work fine with other devices but produce the same problem on my tablet.The same happens when I connect it to my computer via USB.
Unitedfan519
4
Did I offend anyone or make a mistake that is frowned upon here that I am on the "no helpful advice allowed" list?
bascombecurrey
