G Gurj B Member Jan 11, 2014 9 0 0 Jan 11, 2014 #1 I turned on my data few minutes ago and it was showing a symbol in the status bar of LTE but now after I am using data again it is now only showing the 4G symbol in status bar how can I make sure only the LTE symbol shows? Thanks From my Note 3
zmann Well-known member Nov 9, 2010 3,306 120 0 Jan 11, 2014 #2 I don't know, that's weird. My always says 4gLTE. Both, always. THE BEAST,,NOTE 3. SIZE IS EVERYTHING!!!
J jcampbell1070 Well-known member Nov 27, 2013 85 0 0 Jan 11, 2014 #3 You may be on HSPA 4g data and not on 4glte Posted via Android Central App
U UJ95x Retired Ambassador Aug 26, 2013 9,336 0 0 Jan 11, 2014 #5 Gurj B said: I'm on LTE/WCMDA/GSM Click to expand... Yes but if there is no LTE in your area, you'll only get 4G What carrier is this btw? Posted via Android Central App
Almeuit Moderator Team Leader Moderator Apr 17, 2012 32,273 23 38 Jan 12, 2014 #6 Gurj B said: I'm on LTE/WCMDA/GSM Click to expand... UJ95x said: Yes but if there is no LTE in your area, you'll only get 4G What carrier is this btw? Posted via Android Central App Click to expand... This. Just because the phone is set to LTE doesn't mean the signal is their. What carrier? Sent from my T-Mobile Note 3 using AC Forums.
G Gurj B Member Jan 11, 2014 9 0 0 Jan 18, 2014 #7 Thanks I figured it out you were right LTE only shows up if I am in a LTE covered area. If I am not it shows 4G
