Why is my battery draining quickly and getting hot?
  • Start date Start date
A
AC Question
why is my battery draining quickly and getting hot!
I have a lg g3 and I just got this new charger. I've noticed that my phone takes longer to charge and doesn't stay charged long. The phone also gets hot to the touch if I've be on it for an hour. Once as i was charging the phone it had about 30% and it said 1 hour and 50 minutes til fully charge. Then I looked back and it said 50% 3 hours till charged. Also after getting it off the charger at 60% and have being on it for about 30 minutes I noticed that I had 20%. I don't what's wrong and if it's something to do with the charger or the battery. Also I have tried using another charger and it's doing the same thing.
Re: why is my battery draining quickly and getting hot!
Hi, have you tried using a new battery? if you replace the battery, make sure you use a charger that LG provided or at least buy a replacement charger from LG.
Buddylyon
