Why is my battery draining so fast?
  • Start date Start date
A
AC Question
my batorry draining very fastly
from 3 days my batorry is draing very fastly it lasts for only 5-7 min after full charging..problem doesnt end here when get offed i kept for charging on motorrola charger while charging i am not able to see charging symbol so i am complitelly anaware whether charging is started or not....i always use charger i reaceived from company in fact i do by plug as per instructions.......requesting suggest remedy which will work soon as possible imp...unable to see sign of charging
Re: my batorry draining very fastly
Welcome to Android Central! Which phone? Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
http://forums.androidcentral.com/am...ide-how-post-screenshots-android-central.html
If you're able to try a new or different battery, do so.
Gailweeks
