Why is my battery draining so fast?
  • Start date Start date
Re: why is my battery draining so fast
Can you post screen shots of your battery stats? You will have to join to post them, but joining is free and it's a great place to be a part of.
Galaxy s4 mini
Lower the screen brightness. Clear the running apps. Turn off the WiFi when you are not using it. Turn off the mobile data (3g, 4g). Turn off the GPS, The automatic sync option. Turn off everything that you are not using.
If you have a custom kernel, that also can be the source of the drainage.
Turn off the mobile data .... if you turn it off .... the battery and your phone stay cool ... does not overheating ...
Nehasingh12
