Why is my battery draining so quickly?
  • Start date Start date
A
AC Question
my battery draining very sharply
I am using moto e since 2 year,but from the last 2-3 month i am suffering from battery problem, its drain very sharply sometime it fall from 40% to 0%,or 30-0% within few second.what is the problem please explain..
Re: my battery draining very sharply
The battery may simply need replacing.
hey, try this just incase, check all apps in your phone, then check if there's an apps always running in the background that may cause your battery to drain, you need to stop it and check you data just incase its open you should close it unless you are using it. hope it will work for you
18freedom81
