Why is my Galaxy S6 Edge so slow and unresponsive?
  • Start date Start date
A
AC Question
I have a Samsung Galaxy S6 Edge that I bought when Samsung updated the lineup. My previous Samsung phone is the Note4 and the reason I got rid of that was because it was just ridiculously slow and unresponsive.
There are many instances where my phone basically is useless. From the first thing, when I boot it up, it will basically be useless for at least five minutes. It seems it will crap out when it hits like a dozen notification at once. So I have to let the phone sort itself out from that. Great, then it wants to update apps, it will take forever. For example the Play store app the progress bars will says 'Downloading' and the screen will freeze, and then the next thing it will say 'Installing' then free again. I know this is just an app, but when it freezes, I can't use my phone, even if it's updating in the background. It's not just this. Another example is if I take a picture, sometimes the camera will crash. I just was watching TV and there was this commercial comparing the speed of the camera of the Galaxy S6 to that of the iPhone 6s. Yes, the camera on the Galaxy S6 is fast, no doubt, but it crashes half the time. That makes the speed kind of a moot point.
The really frustrating thing is my battery life is also non-existent. From typing this post, my phone running super hot, the battery life went from 65% to 40% in the span of 15 minutes. At least the charger is super fast, so I can survive.
I seem to have lag and crashes to the home screen just about all the time. Maybe, except for Chrome. I don't have any customizations on my phone, running everything stock Samsung. I always use two phones, so I keep an iOS device (currently an iPhone 6s) and an Android device, so I'm would like my Samsung not to struggle so much. I'm just wondering if my phone is broken somehow? I tried resetting everything and if I don't install any apps, it seems fine, but once I install the apps I need, the phone doesn't work well anymore. I've made sure I have the latest updates.
The thing is I called Samsung and I'm told nothing is wrong. I have the wrong apps installed, nothing they can do for me. So I'm at a loss here. And it seems I only have problems with my Samsung devices. I also own a Google Nexus 6P and a Huawei Mate 8, both which run spectacularly, have battery life for all day, no response issues, apps don't crash. All my issues are with Samsung devices, especially this Galaxy S6 Edge that I'm trying to use as my main Android phone, but it's not really working.
Any help or advice for me here?
I had the same issues with my s6 edge, dumped it for a 6P.
Do a factory reset. It looks like its a bad android install. Factory reset will fix the lag and issues.
If it's still the same after factory reset, reflash your phone using odin.
Posted with ❤Love❤
noroldie
