Why is my Motorola Motto phone battery draining so fast?
  • Start date Start date
A
AC Question
The battery doesn't even last for a day with minimal use. Help. Thanks
Hi, every battery is different depending on the users use - you will need to create an account with us, post pictures of your battery stats then we might be able to assist you.
A couple of quick things to look out for:
1) Screen brightness = have it low, about 30%
2) don't use power hungry apps, such as games.
3) Ensure "location" is turned off or on battery saving mode
4) Go into Settings / Accounts / Google then turn off some of the sync options as these can be battery drainers!
stsuvo
