Why is my note 3 battery dying so quickly?
lazyllama27
I have had this note for about 6 months and am having some issues with battery life
1. I notice that my battery% changes when I restart my phone
2. It just drains incredibly fast about 1% every 2 or 3 minutes
3. I Thought it was a worn out battery, so I ordered a new one but it drains almost as quickly.
SpookDroid
Ambassador
Jul 14, 2011
19,325
591
113
Battery drains are never easy to diagnose, but a few starting points can be checking your battery report and seeing what are the top 5 'consumers'. Usually location services can drain your battery quite fast, so check to see if you have any app using High-accuracy location services too much.
GSam Battery Monitor gives you a more in-depth analysis of what's running in your phone, but requires just as much analysis from you to actually make sense of the information it provides. But it's a start and you can always post the list here and me might help with finding out the culprit.
lazyllama27
Here is a screenshot of my battery usage, looks pretty average if you ask me.
I am wondering if there is just an issue with my phone reading the percentage or something
ps. My location settings are always on "power saver"
SpookDroid
Ambassador
Jul 14, 2011
19,325
591
113
Can we take a look at the graph from the system? The one that says how long it's been on and the top consuming apps?
Also, if this is a newer phone, you could try 'recalibrating' the battery readings. Charge it to 100%, let it run down to 0% (it's not actually 0, the phone will shut itself down before that), recharge to 100 and use as normal. That will usually give a more accurate reading if you think your phone is giving out 'wrong' information.
akaalid
