A
AC Question
My Note 4 is taking too long to fully charge
My note 4 takes forever to charge fully, the charging is fine until it reaches about 80% then it almost stops charging completely. I have tried many solutions like:
-charging the phone while switched off (no solution)
-removing the battery then re-inserting it ( charging moves forward a few percent then the problem returns, I have to do it again and again to reach 100% charge. After removing the charger the battery discharges to about 80% within a few minutes even without using the device)
-tried to disable fast charging but had not effect
-tried using different chargers, still no solution
-and lastly I did a factory reset, but problem is still there
so guys I've given up trying, so pls if any one had similar problems and found a solutions pls share.
