Why is my S5 not connecting to one specific WIFI network?
  • Start date Start date
A
AC Question
Not connecting to one specific WIFI network
Hello!
I have a Samsung Galaxy s5, and recently updated to Lollipop. Had all the major problems reported, so I did a system restore which fixed a few of them. My most pressing concern, however, is that I can no longer connect to my work WIFI. I had no problems connecting prior to the update. The WIFI is set up where you connect, and then a webpage should open up for you to login to the system. My browser opens, but will not load a page. The progress bar gets stuck on one spot.
Does anyone have any suggestions as to why this is happening?
Re: Not connecting to one specific WIFI network
Hm that is strange. Is anyone else at work having this issue with the login page?
One coworker that I know of, but he has a Samsung Galaxy s3 and has a lot of connectivity problems. I work for a college, so it's entirely possible other people are having the same issue that I just don't know about.
Retinaclearreviews
