Why is my wifi connection gone after a few minutes on lockscreen?
Tristan Struiyck
3
Why is my wifi conection gone after a few minutes on lockscreen
So i got this issue with my wifi its like when i connect to my home wifi and like turn my mobile on sleepmode(lockscreen) and then after a couple of minutes i want to browse internet or play some internet required apps but cant because there is no interter,However on top of the screen i just see the wifi bars full and the mobile is connected to internet.
This problem is only with my home internet and only with my mobile.
Re: Why is my wifi conection gone after a few minutes on lockscreen
Do you have an active Wi-Fi connection? I would suggest reseting the router and see if that helps. If it's connected to the internet, then the games or web browsing should work despite Mobile Data being disabled.
Have you a second phone with the same mac id? This happens if you use a custom rom for example.
Mmh iam not sure if it have same mac id as an other device i should check this,and as for the mobile data its on
Qmoitramer
