Why is there sound delay? Lenovo k6
Tepp3
I've just bought new Lenovo k6 and everything is fine but I found this problem with YouTube videos. The sound isn't matching the video. There's difference like half a second but it's very disturbing. Can anybody help? Thank you in advance.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,778
4,989
113
Welcome to Android Central! Are you using the phone's main speaker or a Bluetooth speaker/headphone?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,778
4,989
113
How many videos have you tried? Just want to make sure it's not specific to one particular channel.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,778
4,989
113
Are you using the YouTube app or the mobile site on your browser? If the latter, try using the app. If it's happening on the app, try going to Settings>Apps, select YouTube, then Storage, and Clear Cache/Clear Data, and Force Stop. Now open it again and see if the problem persists.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,778
4,989
113
If the problem recurs in normal mode, you may have to start uninstalling apps one by one until the problem goes away. Unfortunately, there isn't an easier way to pinpoint the culprit, unless other people have experienced the same issue and can give you a hint.
