Why isn't my battery charging?
  • Start date Start date
A
AC Question
My battray not chargen
I have samsung galaxy s4 1 year old
my battery was not charging New battry I also ordered same problem
* phone's memory and switch off all eight charging or if it was loaded but I do not get that too battrey sigenaal loaded and I have my phone also format or restored. prbleem still charging
Re: My battray not chargen
Perhaps the phone's USB connector is dirty or damaged.
My S4 has a bit of a problem with its battery. It's nearly 2 years old so age may be my problem. It will be at 97% & if I go on my phone to check notifications it will jump to 100% in a few seconds. If I take it off charge it says the battery is 98% charged. Any ideas on this?
Sorry I can't help with the OP & I didn't wanna make another battery thread.
You should expect a battery to last around 18 months. If your phone is 2 years old I would suspect the battery is the problem! Lithium batteries should last around 500-600 charges under ideal conditions. 600 charges would be about 20 months. I would replace the battery soon!
Well I'm getting a new phone in the middle of April so I'm hoping the battery will last until then. My phone will be 2 years middle of April.
check charger block, usb cable, and if it still doesn't charge, it's the usb port. try usb > computer. if the computer doesnt see it, its the usb port.
amazon/ebay has battery+charger for pretty cheap
dumpsterrentals102
